1 - 4 of 4 Posts
i have a dell 531 inspiron pc, no dvi out no real output to the philips flatscreen, if i take it to bestbuy and have then install a cheap card with dvi,hdmi out, then all i need to do is connect the cables to the tv so i would be able to watch the flatscreen as my monitor?
this is the video card ***
Product Features
Powered by the ATI RADEON HD2400 XT graphics processing unit (GPU)
256MB DDR2 memory
PCI Express x16 interface
From our expanded online assortment; not available in all Best Buy stores
700MHz core clock speed
ATI Avivo HD technology video and display engine allows you to connect to high-definition displays with high-definition audio support
DirectX 10 support enhances gameplay by delivering sharper images, more textures and the improved lighting effects that create lifelike interactivity and immersive realism
Windows Aero user interface and ATI Catalyst graphics management software ensures a quick and easy setup of graphics, video and multiple displays
Fully integrated high-definition audio support enables playback of multichannel (5.1) audio streams; compatible with HDCP for HDMI connectivity
Outputs: 1 DVI-I, HDMI, VGA
Compatible with Microsoft Windows Vista
then can i just buy a hdmi cable and hook it into the tv?
or can i also buy a dvi --> component cable and achieve the same result?
thank you os much for your help
The DVI to HDMI adapters are cheap though. I even have a cable and adpater here I no longer use that I was thinking of selling on eBay for $50 or so...PM me if your do go that route and need this one cable/adapter set I no longer use.
1 - 4 of 4 Posts
