Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
Took a look at three 42" plasmas side-by-side today at ... well
never mind the store. One was a Philips (42FD9932), one a
Sony (42B1U I think) and the third was a Pioneer, the model
number of which I missed. They were all showing the same
thing.
The Philips picture was great, very smooth, very clear; both
of the others suffered from what I thought was pretty visible
'jaggies', at the edges of blocks of color and on diagonal lines,
especially as the camera moved, the edges didn't move
smoothly from pixel to pixel and the edge therefore seemed
to crawl.
The sales droid, who was demoing this to a customer, was asked
about the resolution on the Philips (which clearly had the better
picture) and stated it to be 780 vertical. I thought, ok that's why
the picture is better, and went home. Then I checked it out, the
droid was wrong, it's 480 like the others.
Is this likely to be a setup issue between the TVs? I have seen
the sony before and at the time I thought it was smooth and
something else (Pioneer I think) was jaggie. Is the Philips known
as a particularly good unit?
Roland
· Registered
There was something very. very wrong with the setup there. The Philips is one of the worst 42" plasmas out there. The Sony and Pioneer have their problems, but they should have been visibly better than the Philips. If you want to see what plasma is capable of, take a look at a 42" Panasonic that has been set up right on a DVD via the component input or, even better, a 1080i HD picture.
Awesome!
1 - 2 of 2 Posts
Status
