Holy crap not, you are using a pistol polisher? They are great for small areas and door jams etc but I'm surprised you don't have a full 8".
Not, you should try out the mini woolys for your mini! They are fantastic for small areas. Also not sure if you use one but the blue pads are the compounds pads for the mini, tan is for glaze. Though you likely already know that and were glazing before the pic, just saying in case since the blue pads do twice the work in half the time as the tan with compound.
