Dumb question... Is there a way to do a roundover without a router? I don't have one.
Sent from my Nexus 7 using Tapatalk
Compare in what way?
I never had them in the same set-up actually. They have a similar sound so it would be fine. The F12 sound much much better than the F8 though in my opinion. If you only have one or two "sweet spots" just running a phantom center channel might be better.Reviving an old thread.....
I'm looking to build mains to go with my Fusion 8 center channel.
How does or did the Fusion 8 center work with the Fusion 12's?
That's a great idea!I never had them in the same set-up actually. They have a similar sound so it would be fine. The F12 sound much much better than the F8 though in my opinion. If you only have one or two "sweet spots" just running a phantom center channel might be better.
