Status
Not open for further replies.
1 - 4 of 4 Posts
Hello all, Just hooked up my utv for the picture in picture feature. The problem being only a few channels work on the pic in pic screen. The rest say searching for satelite signal. I went into settings and both tuners are locked in at 88 and 76 respectively. Any ideas or has anyone else run into this before?
thanks
Bennydog --
Check the signal strength on all of your transponders. I'll bet some of them are showing low -- either for 1 tuner or both tuners.
Problem could be either the tuners (less likely but not impossible) or the connectors on the cable (more likely especially if this was a self-install).
The "searching for satellite signal" message means exactly what it says --- the tuner is not getting a signal. So if you have a primary picture, but the PIP windows contains the message, then the tuner being used for the PIP window is not getting a signal.
I had no signal on 1 of my UTV's tuners but only on a couple of transponders. Replacing the connectors I crimped myself solved the problem.
You will have to do some process of elimination (switching incoming cables, etc) to determine which one is not right.
Good Luck,
SteveK
1 - 4 of 4 Posts
Status
