Status
Not open for further replies.
1 - 4 of 4 Posts
hi everyone
I am using the following setup and find the picture to be a little soft ..what can I do ..
Nec projector .. using windows xp/ radeon 7200 with the vga cable / have powerdvd xp and theatretek 1.5 ..I have setup the colors and brightness and stuff using avia disk .. but I cannot find anywhere to setup sharpness on the projector or the computer ..I am using this 100% for dvd viewing on a 12 ft screen in 2.35 aspect ratio ..
thanks
Zee
Your setup is very similar to mine:
XP
NEC MT1040
Theatertek 1.0
Radeon 7200
Here's a checklist...
Projector
1) Turn off Auto Adjust
2) Turn off AccuBlend
PC
1) Make sure you are feeding the projector its native resolution with a 60hz refresh
If this doesn't help, try projecting a smaller image. A 12ft image is mighty large depending on how close you are sitting and how bright your projector is.
Kevin.
At XGA (1024*768) resolution, a 2.35:1 image would have only 326 lines of vertical resolution.
On a 12Ft screen that translates to 61.3 inches or 0.2 in per/pixel!.
Your image is probably not going to get any sharper.
In any case, have you tried FFDshow w/ TT?
BTW, I use a 109" 2.35:1 screen with a DILA (1365*1024).
When watching scope movies, they tend to be a bit soft, but much better than a previous NEC LT100 I was using. (435 pixels vs 326 pixels).
that seems like a AWFULLY large screen...i would think that is the problem as well.
brickie
1 - 4 of 4 Posts
Status
