1 - 3 of 3 Posts
I went home for lunch and turned on the TV. The left third was a jumbled mess and the right 2/3 was completely black. The audio was still coming through. When I hit the guide button on the remote it came up just fine on the entire TV
I have an HDMI running from cable box to receiver and another running from the receiver to the TV. I tried messing with the plugs, but nothing fixed it. I did not get the opportunity (had to come back to work) check the connection on the back of the cablebox, but I assume it is fine if the guide would pop up and look normal...
When the guide is up, the jumbled mess moves from the left 1/3 of the screen up into the corner where the TV show would normally be when you are looking through the guide. Any ideas?
Discussion Starter · #3 ·
Are you thinking that it's more likely a source (cable box) than the HDMI cable itself? That's kind of what I'm thinking...
1 - 3 of 3 Posts
