Originally posted by melduforx
Yeah, that will work fine. Just connect the WHITE audio cable to the audio in jack on your TV. You will get mono sound. |
I'm a little curious how the Replay will know to send Mono sound when you only connect the left or right channel. Most devices actually need to specify that you have mono sound so it will send both the right and left channel over the single RCA wire. I believe if you do it this way, you'll might miss out on some of the sound.
If you want both the left and the right channels combined, you can buy a "Y" adapter from radio shack for a few bucks to combine the channels.[/b] |
Does that really work? Being in electronics, we were taught never to connect two different outputs together in this way. At best, I'd think you'd get some signal cancellation, at worst you might blow up something (however, I believe the RCA outputs are pretty well protected). Seriously, I have no idea, but I just can't imagine that working.
Hooking a VCR up in between won't really buy you anything. You'll still have mono sound, because very few devices have stereo RF modulation over coax -- it's very, very expensive. [/b] |
Hooking up a VCR in between my Replay and TV has greatly improved my picture quality (and that is really what this thread is all about). When I hooked the coax output directly to the TV, the picture looked very grainy and noisy. When I hooked the output of the Replay via the RCA connections to the input of the VCR and used the coax out of the VCR to the TV, the picture looked perfect. So in short, not only does the tuner inside the Replay suck, but the output via coax sucks as well. Besides adding picture quality, it puts a VCR inline with your Replay, so you can record shows on VHS tape for friends and family who don't have a Replay as well as watching stuff you might still have on VHS.
Originally posted by rm -rf *.*
Rather than connect the ReplayTV RCA/S-Vid to a VCR and then RF-Coax out of the VCR to the TV (to me, this arrangement screams "SIGNAL DEGRADATION", especially considering how cheaply-made most VCRs are these days, but that's just IMHO...)[/b] |
I disagree with this statement (as I stated above). In my case, I already had a VCR, so the cost was nothing. I was thinking about buying one of those RF-modulators, but why do it if you already have a VCR lying around (and many people do). However, I suppose I would try the modulator before the VCR if I didn't already own a VCR since it is cheaper and takes up less space.
