Status
Not open for further replies.
1 - 2 of 2 Posts
When watching HD with the HD-100 on a Mits 73903 using the VGA output on the HD-100 the picture is shifted about three inches to the right. The TV is calibrated using the test patterns on Avia, the DVD player is connected through a Crystal Image. Is there a problem with the HD-100 or the CI?
Mike
Discussion Starter · #2 ·
I heard back from a tech at Sony. He said that this was a known problem and that there was no fix planned at this time. The options were to adjust the TV to compensate (which would throw other sources off ), use the component outputs, or return the HD100.
Mike
1 - 2 of 2 Posts
Status
