221 - 240 of 523 Posts
Check MPJA.com for punchdown and RJ tools... one of my favorite hobbiest sources.
DC,
I just went to Lowes and picked up the RJ45 and phone connector crimping tool kit. Not sure what it is called, but terminating my ethernet wire was much easier than I thought. I have always done all my RG-6 stuff, but I highly recommend you do it yourself.
Oh yea, your room is looking sweet as well!
Dave
Premium Member
Discussion Starter #223
Thanks Dave - you must be enjoying yours a lot these days. I'll catch up eventually.
I did an inventory. Looks like I have 6 ethernet jacks to terminate and about 9 coax to terminate. Looking at what I bought on closeout, the quickport F connectors are desinged so you terminate the wire to a standard end, then the quickport is basically a bracketed coupler that fits neatly into wallplate. Glad it isn't expensive. Anyways, since ethernet looks pretty straight-forward, I'll probably try a couple with the included tool and see how it is. I can always tighten it up with a proper punch tool if I get one, as a user suggested in PM. For the coax, I am going to look into the compression connectors Bud mentioned, and go from there.
On a different note, I was leaving work today, and I noticed that the security guard, who was elsewhere at the time, had left his computer on, with the browser pointed to AVS. He was reading an owner's thread on a display that didn't ring a bell to me. There are a couple different night guards, so I'll have to figure out which one it was.
Premium Member
Discussion Starter #224
Okay - our contractors are gone, and we are going to re-work a few things we didn't like.
The first project is in the playroom. An HVAC vent goes under a beam, and the box they made wasn't what we were looking for. We asked them to re-do, and the second draft was done pretty sloppy. So DIY. Here is an old shot of what we are working with. Its a tight crop on a low rez shot, so not great. There is now molding around the open space below, and the wall is now primed, not painted yet.
The vent profile looks kind of like this:
__/
We are trying to hug the enclosure as tight as possible, to make it as unobtrusive as possible. We are novices, this is our plan: - use 1x1 or smaller (maybe 1x1/2) to "frame" the vent. Attach them to the plaster+blueboard wall with liquid nails + a crown stapler. There isn't a lot to bite into (1/2"blueboard+veneer plaster walls), so I am thinking smaller fastners is best, it only has to hold it together. We would then take as thin of blueboard we can find (1/4" if we find it or 1/2"), and either glue and staple to the framing, or glue and screw. We will then plaster (we have a wall in the utility room to practice on), prime and paint it to match the wall.
Any flaws in our thinking? The thinner materials might be a little flimsy, but it is just cosmetic in function.
Premium Member
Discussion Starter #225
Finished re-securing the rack. The carpenter left it with only a couple screws in place because I wasn't there to supervise. So I took it out, lathered it up with construction adhesive, put it back in the opening. Clamped it and let it dry. I then painted the wood liner black, and put the rails back in last night, using a bunch of screws. I then attached one of the crown 402 amps, using just the 4 screws in the faceplate. This amp weighs around 25 lbs, and I wasn't sure how stable it would be held in with just the screws in the faceplate (I don't have rear rails). But it is solid as a rock. I am really pleased.
My door will go up later, as I need to work out a couple details on the trim. My hinges got misplaced, and the replacement set arrives today.
Here is my plan for the rack. Spaces went awfully quick. Shoulda gone bigger. I am tempted to move the amps to the bottom, since the sources would be better at eye level, but this plan seems better from a heat perspective. I have a few 1U blanks/vents in the plan that I will be ordering. I need to buy shelves for the receiver and sources too. And the drawer. Any flaws? I'll get a couple pics of the rack in the next day or two.
Dave, FYI. When I installed my power conditioner, I installed it in about the same location as you. Made sense to me initially, figuring it would be an equal run for equipment above and below it. If you install it on the top or the bottom, some components may have shorter power cords, so a potential issue.... BUT, the problem is that there is a master switch to kill it in within reach or kids. Also, the wife didn't know any better and just killed everything to the rack. Nothing tragic, just something to think about.
Bud
Premium Member
Discussion Starter #227
Not a bad thought Bud. My rack has a door which might protect against prying hands - but I realize now the lock on the door is meant to go into a full rack, not just rails. So I need to provide for a latch for that to be any defense - I didn't have a lot of thought into the power conditioner's placement, except it has a convenience outlet on the front (and several in the back) which I was trying to keep convenient - - though I will probably never use it.
I am debating custom mounts (pretty yes, but expensive and behind a door) and whether to ditch or downsize the drawer. I'd like to leave a little more space for expansion (eg another amp when I go 7.1 down the line, maybe HTPC or a scaler) but I think I'd like a place to store sundries like remotes and whatnot.
But if my door winds up being unlocked, I agree the power conditioner is going higher. My daughter loves buttons. Good tip.
Premium Member
Discussion Starter #228
Here is a few pics of the re-worked rack.
Re-installed, with all my rack-mount stuff installed (one amp needs to be moved down a slot, may eventually paint the NEC switcher black)
A closer cross section shows - some rough plaster, the painted wood lining the opening, the rails, and part of a vented blank
Back o'the rack-
Now here is what I am thinking about the door. The doors are made for full racks, and the instructions suggest on a full rack you just install the hinges on pre-machined slots, and walla. With rails only I will have to improvise. Calvin gave me a few pics in his thread which showed me how it sits in its natural setting.
My plan is add trim over the wood and plaster, flush with the inside seam of the wood, and the door will rest on the trim (to be painted black).
I would then just add the hinge to the meaty part of the trim, piercing it, and ultimately anchoring in the wood behind it. My fear here is that the trim will split (it comes in pine)
For context, the top hinge just rests on top male/female style
Then next concern is that the keylock will need to "lock" by cutting a slot in the trim. From what I have seen on the web/tv, a biscuit joiner would be ideal for this - I don't have one of those, so I will have to try a manual cheaper tool. I am thinking either perforating with a drill and then a knife, or maybe the hand-held drywall saw I just picked up.
Any flaws?
Be sure to pre dril your holes for sure to avoid splitting, as for the slot, do you have a router? you might be able to use a fine bit. how about a Dremel tool?
Where are you on the S. shore? might be able to loan you a biscuit cutter.
As always, McCall made a good suggestion. If you don't have a dremel, I am pretty sure you can get a drill bit that has a disc-shaped cut-off attachment. As a last resort, and if you are careful, you can just use a chisel and do it by hand. then cover the hole with a pocket door latch plate. You can get them at the home depot (probably need to buy the whole pocket door latch kit) here is a pic of what I am talking about, it's the little plate on the side:
click here
Premium Member
Discussion Starter #232
McCall - good idea to pre-drill. Probably would have done that, but I sometimes can be lazy and try to push the screw in. Based on a conversation via PM with another member I am leaning towards notching the trim at the latch and securing a metal plate, as the wood wouldn't be terribly strong. I also sent a message to tech support at middle atlantic to see if they had any comments. They asked a quick follow-up question and have been radio-silent - but I'll see what their opinion is.
I am in Raynham. My [growing] tools selection is pretty much miter saw, sawzall, couple drills, compressor+ nailor, hand tools, and a new shopvac. I should be able to notch it with some of these though.
Mark - glad you enjoyed the thread and took the time to read. I am not the artisan that some of the builders are here, but I do ask a lot of questions so there shouldn't be too many mysteries about by thought processes. Welcome to the thread and thanks for the kind words.
Dave- get a basic Dremel kit. I can't tell you the thousand uses you'll find for the tool during day-to-day house maintance projects. You don't need the super kit - even a $30 Black-n-Decker version works fine.
Premium Member
Discussion Starter #234
Michael - probably a good purchase. I'll add it to the list. I have wasted a bit of time watching the dremel infomercial, I am embarrassed to say.
Got a reply from Middle-Atlantic Tech Support. They suggested I return it. I think I can make it work without needing to do that. I appreciate the prompt reply though.
Hello Dave,
We do have a door that attaches to rackrail but the largest one is 20
spaces.
http://www.middleatlantic.com/rackac...y/security.htm
I suggest you return the PFD-35 and get a door from the hardware store
or Home Depot that was designed to attach to millwork. Unfortunately
our door was not designed to be attached to millwork.
Well that sucks. At least they will take it back. You thinking of going all McGyver making it work anyway?
Premium Member
Discussion Starter #236
Yup, pretty much. I don't think I'd come up with a better option at HD. I'll need two holes per hinge, and an approach on the latch. It isn't like the door is structural. Besides, I ordered it online (from a reseller - MA doesn't do direct sales) months ago and this crate is no longer with us:
I need to buy more trim, get that painted and give it a shot. The good news is the modular hinges mean I can't really damage the door in anyway - though can't say the same for the to be added trim or the 1x4 behind it. What's a few drill holes, right?
DC, post some closeup pics of the hinges and latches... I've got several racks with unused doors and I may be able to provide the correct striker, or thoughts on how to do the striker/hinges cleanly.
Premium Member
Discussion Starter #238
JTN - I will take a few shots tonight. The hinges are basically four pieces. Two male "nubs" (no idea what the right term is) that affix to the rack/wall (top and bottom) and two female "nubs" that affix to the door.
Calvin posted a few pics in his thread that show how the install looks in a full rack setting (click for bigger pics).
Originally Posted by Calv1n /forum/post/0
Door popped off:
I need to pick up some more trim first, but I am hopeful that it won't be too bad as long as I use the right anchors, and measure twice.
Premium Member
Discussion Starter #239
click here
Rob - I was posting at the same time as you, so missed this post till today. Good suggestion on a drill bit alternative, although I am pretty easily talked into picking up a dremel. A pocket door latch is also a good suggestion. Probably a more pro look than me digging around for a piece of metal to insert.
Premium Member
Discussion Starter #240
Forgot to grab a latch shot. Here are a couple of the hinges. I think at this point the plan is simple - measure the heck out of everything. Pre-drill the holes through the trim and into the side of the of the 1x4 beneath it, and screw securely. For the latch I will either dremel the side of the trim and insert metal reinforcements, or cut some trim away and affix a piece of metal in the place.
How they connect
