101 - 120 of 523 Posts
Lookin real good DC, keep up the great work. That rack door looks very impressive! Can't wait to see the finished product.
Premium Member
Discussion Starter #102
Judson - thanks for the link. Perfect. There has been a little activity around the air return. My HVAC guy pointed out that we really want to anchor it to the staggered studs on the HT side, so there will be a bit of rework there. I'll post pics when its done.
Cherokee - thanks - things are coming together. My wife pushed for the door to keep little hands out. Now that I have it, I think it was a good call.
In other news, I posted a minorly silly picture of myself on the web, and won a blu ray DTS Sampler disc. Sweet! Now that the contest is closed, no reason why you guys shouldn't see my winning entry. Thanks to Critical-listener for generously running a fun contest.
link:
http://www.avsforum.com/avs-vb/showt...post10268648
My entry (contest: "why should I get the disc"):
Originally Posted by dc_pilgrim /forum/post/0
If I don't get it I will ride a camel to your house and whack you with my prosthetic leg.
*yes that is me. Note, I have water sufficient for the journey (presumably the camel does too).
ROTFL!!! Great photo!! Gratz on winning the disc.
Premium Member
Discussion Starter #104
Thanks Cathan.
Update - Tomorrow is the craziness. . ..
Blueboard (type of drywall) was delivered today.. Here is the half-inch for the rest of the basement:
They stacked it on its side, which was kind of weird. In all the threads I have read, I have only seen it lying flat on the floor. Perhaps because otherwise there is a risk it will come crashing down on your wife's leg, like these 15 sheets of 5/8ths did:
Needless to say, we had a bit of a scare. I was moving it smidge to look at the HVAC return which had been adjusted today. I wanted to verify the decoupling efforts. In a blink of an eye, gravity kicked in, and 15 sheets were keeling over. I was holding the baby, so my wife rushed in to help. She wound up getting bowled over, and just missing having a rusty nail jammed into her torso - - so we are thankful it was only bruises. So far she is being very gracious about it. Hope it stay that way. Anyways, you can see the return in this shot of the rear. It is screwed to strapping that is not attached to the stud that connects to the utility room side (stag stud):
Moving counter-clockwise, here is the back wall (the sump pit charger is going to be moved):
And the side soffit (taken from the front)
Here is the future screenwall:
Here is a bump in the soffit that we did to mirror the HVAC. We need to decide what we want to do with the front view now that we know we have these bumps. You can see some conduit popping into the room too. I will trim that back after the sheetrock is up.
I added some threaded rod coming down from the ceiling to be used as part of the mount for the CRT projector. It hangs 18 inches. I plan to trim it back after the rock is up. The intention is that RSIC clips and hat channel will ride over the strut attached to the joists (see earlier in the thread) - you will note, there is no RSIC clips up right now, nor hat channel. Yes, the carpenter has a few things on his punch list (including more insulation in the ceiling/soffits). Yes, this makes me nervous.
Here is a shot of the conduit to the PJ. It will be trimmed back after the rock is up. The box is loosely nailed, as I wasn't sure what height to make it, since the RSIC clips aren't up, and the hat channel isn't here (!)
Here is the other end of the conduit in the utility room, where the rack will go, messy, huh?
I am 7 hours away from action. Unfortunately, my job is nuts now also, so I have to go to work tomorrow. My wife will have to supervise for me. Fingers crossed.
Awesome - can't wait to see the updated pictures!
Nice progress Dave,
I was wondering about the blue ring around the conduit ends, is that some sort of plaster ring, does it attach to the low voltage box or does it have the wings for existing work and eventually grip the sheetrock? Never noticed them before at the local home stores.
Glad the wife wasn't badly hurt, I've had nails go through my foot (ya it happened twice when I was young) could've been bad not knowing what it could have punctured.
Premium Member
Discussion Starter #107
Okay - change of plans. Sheetrock guys pushed back to Monday.
I am actually kind of relieved, since the carpenter is still coming today, and will install the RSIC, hat channel, more insulation, and a few other things on the punch list.
Oman - thanks for the concern. Like I said, we are thankful. The blue ring was something in the aisle at HD where I got the carlon box. I think it is a ring for a ceiling fan mount - or something similar. Anyways, 2" conduit fits in neatly, and the screw holes, while not perfect, did line up. I can take more detailed pictures over the later half of the weekend if you like, I have one set loose right now.
If you get to it that would be cool. Seems like a good option to tidy up the conduit. Thanks.
Premium Member
Discussion Starter #109
Oman - wound up staying in NH little longer than planned, so couldn't get more pics. I did find this on the Carlon website. The screw holes that lined up (not quite perfect, but 90%) to the box are the ones on the outer ring (the open one, and the slide-one).
http://www.carlon.com/sd-cgi/hsrun.h...logObjectId=90
In other news, the sheetrock hangers arrived this morning. My carpenter bailed on Friday, so he is finishing up his punch list concurrently. I hope it is going well. Hopefully pics tonight.
Funny story, he hunted around for RC-1 (hat channel) that would fit the clips. When he got to the supply house the guy who sold it asked him where he got the clip he had brought with him. That he'd just seen it for the first time at a trade show a while back. He had to say his client had gotten it off the internet. Thanks Bpape!
Banned
The plexi doors really look good. Wait until you see it with the little lights from all your equipment on behind it. Might sound silly but I dunno, I love racks.
Hm, did they in fact apply it correctly?
Premium Member
Discussion Starter #115
Okay here is the update from the sheetrock hanging day - -
Here is the screenwall. There will be a false wall about 18-24" away, with an AT screen (SMX). I am still thinking through the front. Initially I was thinking no stage, and a straight false wall - not unlike Larry Chanin's (although he is shadow boxed) - now I am debating an arch, or a curved marquee, since those bumped soffits came in.
Here is a closeup of the side soffits in the front. You can see the box for the conduit. The ring got knocked out, and the conduit isn't popping through at the moment, but the opposite wall is still raw.
Here is the threaded rod for the CRT PJ
Here is a close up - holes are a little bigger than I would have hoped:
The return came in good:
Here is a suppy (1 of 2)- quite a gap due to the RSIC clips + hat channel (note some GG):
This close up shows the gap. The HVAC guy is going to loosen it, and bring it flush with the sheetrock, the affix to it when the grates go up.
Here are some of the "empties"
Here is the entrance. The rack isn't cut in yet (I can't wait to see the door in action either Max).
Accross from the rack, is the grafik eye - waiting for action -
I ordered the blue LED rope light today. Went with 1000bulbs - since everyone reports its dimmable. The price was horrendous. I should have quite a bit left over if anyone wants to pick buy my excess off me.
Time for bed. Take it easy all.
I can NOT believe it! They only used 2 of the 4 cases of green glue. They'd need at LEAST a portion of the third (I over order). UNFRICKENBELIEVABLE!
Dave, your Boston is showing
You spotted two unused cases of Green Glue, but not six missing sheets of rock, before posting? You may be a little too emotionally invested in this project!
It's a lot healthier to take a pragmatic approach to major reno projects, and just accept that some stuff will be done wrong and have to be corrected.
When you're all done, I (NEC 9PG) and Chip (a.k.a. stefuel, Ampro 4600HD) would be interested in the end results. Did you say you had a G70?
Out of curiosity, is blueboard any different than "regular" drywall?
I always assumed that blueboard is also less prone to water damage (D'OH (slaps forehead,) plaster is a wet process.)
I didn't plaster, but used blueboard in my bath remodel and in my basement (prevent wicking from concrete.)
Thank for the pics,
Your is project is really starting to come together.
Any concern with using blue board downstairs in the basement. I've always been told at the minimum you want to use green board and more recently the paperless boards to prevent any mold issues.
Edit: jtnfoley just answered my question, I'll have to rethink what I want to do in my basement now.
