601 - 620 of 973 Posts
Mines mounted with a "french cleat". I can offer that I underestimated how frequently I go back there. I assumed it would be a set it and forget it sort of thing, but I've been behind the screen over a dozen times in the last year. MAKE IT CONVENIENT AND EASY.
Definitely make it easy to get back there, Ive been behind mine a lot.
I used a piano hinge on the top and some bolts through T-nuts at the bottom which I threaded in or out to fine tune the "level" of the screen since the top was hinged. I simply pull it out and use a prop once its swung out.
Being able to swing that thing out go back there tweak whatever, swing it back, and hit play without adjusting shift level or zoom is worth its weight in gold....
Discussion Starter #603
Thanks guys - started shopping for piano hinges.
. I'll check your build thread Nick in case you documented your approach - I think I recall seeing it. Not sure you mean about the adjustment mechanism. What do you do about the top false wall panel above the screen, do you remove it when you want to lift the screen up? Since it would interfere with the hinge otherwise.
Bump
Discussion Starter #605
Thanks hanes. I knew you would understand.
Originally Posted by hanesian /forum/post/20673239
Bump
Ah, I feel the love here.
RTROSE
No, I actually mounted a 2x4 horizontally on the screen wall so back of screen is 1.5" off wall. That way when screen swings up it has room to rotate without hitting wall. Also this makes it easier to level the screen horizontally as if the 2x4 is level just mount the piano hinge across it and the screen should be level also. Not sure how you feel about other pics in your thread so if it bothers you let me know i'll take them down and publicly confess my transgressions.....
I never took pics of the adjustment mech, ill do that now and post it because I think its pretty nifty.
Also looks neat to have the screen stand off wall it kinda looks like its floating.....
Warped minds think alike.
My turn.........
Discussion Starter #610
Ummm...
well...
you know that thing they say about what happens when you install the projector...
well...
yeah.
I was going to change a burned out light bulb - but I decided to watch Pan's Labyrinth on the new screen instead.
Ummm...
well...
well...
yeah.
burned out light bulbs are the best cause they don't interfere with the picture quality.
Ummm...
well...
well...
yeah.
Glad you are ready to enjoy.
Spoken by a TRUE home theater enthusiast!!
Nick,
I like your hinge idea. I've often thought of how many times I might need to go back behind the screen but even then I think that it's probably a good idea to have easy access behind there.
Brad,
Can't wait to see your screen all put up and done.
Discussion Starter #616
Thanks Jman - hope the hinges and other needed parts yesterday and started at it, hopefully later tonight will have it up.
Originally Posted by rgoolio32 /forum/post/20697226
What type of bulbs did u use for ur lighting to get that wash out triangular effect on your panels?
The standard bulbs that came with the halogen fixtures: 50W GU10.
Discussion Starter #618
Yesterday I finally got around to hanging the screen. I used a pair of 4' long piano hinges from Home Depot. Because the square metal tubing that stretches the fabric sits proud of the wood frame by 3/4", I first added 1 1/2" x 3/4" poplar under where the hinges go. The poplar strips connect to the poplar frame with 1.25" gold screws; the hinge is connected to the poplar strip with the dinky 1/2" long screws that came with the hinges; the other side of the hinge is connected with 1.25" gold screws to 2x3 cross bracing I added to the false wall. Those 1/2" screws seem a little iffy - but there are going into hardwood, and there are a LOT of them (about every 2 inches along the hinges), so hopefully it will be OK, as the screen isn't all that heavy.
I still haven't painted the vertical braces, you can see the reflection from the flash. I'll need to take one of them out, paint it, wait for it to dry, put it back, and then repeat for the second one - so the screen stays stretched. Or maybe I could make a temporary wood brace to keep it tensioned and work on both braces at once.
The faint circle on the left of the first pic is from the camera, not the screen material - tiny raindrop landed on the mirror when I was changing lenses during a holiday trip, and I haven't gotten around to cleaning it.
Here's the screen, under full light:
under low / screen wash light:
hinge detail:
reference screen shots:
more screen shots - 2.35:1:
16:9
stretched 16:9 (zoom to widen, throw away some content on top and bottom) - I accidentally watched some 16:9 this way because the velvet frame eats light so effectively that I didn't notice I was overshooting quite a bit. Not bad depending on the content.
Wow Brad! Stunning! Hey, my screen is on a french cleat, but the thing is so big that I have nowhere to put it when its off! I think your hinges look great, and I'm going to amend mine to be that way. Having it pinned to the ceiling when up is about the most convenient solution.
Screenshots look great too. You're going to be having some fun!
Brad for me to form an opinion I am going to need MORE screen shots........LOL
Looks awesome. The piano hinge idea is perfect and the 1/2" screws will be plenty since there is a few dozen of them. Looks great but the new screen shows me why your MW2 skills are lacking a bit
