941 - 960 of 973 Posts
Banned
Originally Posted by Brad Horstkotte  /t/1250265/pimp-my-garage/930#post_23392505
Hmm, I guess I might do something similar to what I went with, but probably would have gone for the SEOS-15s in plastic, and the 8 Ohm 2226H instead of 2226J. Or one of the Jeff Bagby SEOS designs? Hard to say without hearing them of course, I went in blind and I'm quite happy with the results. The SEOS-15 and the 2226H would be better on paper, but no idea if I could actually hear any difference, probably not. I don't play loud enough (-15 to -10) for the sensitivity to ever be an issue.
A 2.5 design would be cool too (two 15s), but would need even more help with crossover design.
How much did you pay for the 2226h ? Where did you end up getting them ?
Discussion Starter #942
I got them from ErichH for $125 each, before shipping. They were leftovers from a group buy thing where he got a bunch of JBL cinema stuff that was pulled from some large theaters. Long gone by now I think. Shouldn't be too hard to find them on eBay, for similar price or maybe a bit more - I felt a lot better getting from Erich though, since I knew he wouldn't sell anything that was iffy at all, vs eBay sometimes you get what you get (like non-JBL recone).
Discussion Starter #944
Discussion Starter #946
Hard to say, as I haven't heard those - I'd take a look at the DIY Sound group forums for comparisons and also the SEOS thread, some of the builders should be able to comment on the ones they've heard - as for me, the ones I built are the only SEOS designs I've heard in person. I like em.
Just add water and stir
Originally Posted by Brad Horstkotte  /t/1250265/pimp-my-garage/930#post_23464091
Deals like this make my heart smile
Brad,
Much kudos on your build..impressive. Has given me a lot of ideas. I really like your columns given the narrowness I am dealing with in the room. Did a search on the thread but I cannot find the dimensions or rough drawings anywhere. Would you be able to provide several rough dimensions and/or drawings of the framing of those columns? Thanks!
Discussion Starter #949
Thanks much reb - there are some bookmark links on the first page of the thread that lead to posts related to the column building - I don't have measurements or drawings handy, although I think some of the pictures in the build should help you visualize how the columns are constructed. I'll do some measurements when I'm back home and get back to you.
And thanks for the thread bump
Brad I don't know if I thanked you yet? My room is 19’x23' so I sole er borrowed a lot of your ideas. The main difference being mine build was 2nd floor over the garage so I had to do some engineering around the sloped ceiling for my columns. The main reason I am checking in is to tell you about my screen. I used your advice and went with a DIY 2.0:1 constant image area format screen made out of Seymour Center Stage XD materiel.
The 126"x65" constant image area 2.0:1 that gives me
126"x52" 2.40:1 with 136" diag, 6 12" bars top and bottom
126"x54" 2.35:1 with 137" diag, 5 1/2" bars top and bottom
120"x65" 1.85:1 with 137" diag, (man this size make it like being there) 3" bars both sides
116"x65" 16x9 with 133" diag. 5" bars both sides
So in the way the best of both worlds If I would have done a 2.40:1 screen 126" wide my 16x9 size would have been 92"x52" with 106" diag. If I would have done 16X9 65" tall my 2.40:1 would have been 116"x48" 126" diag.
The frame and 2x4s made it so dark I had to turn my back lighting on to get some good contrast.
http://s629.photobucket.com/user/cw5billwade/media/theater/20131229_215131.jpg.html
This shot best shows all my colors
http://s629.photobucket.com/user/cw5billwade/media/theater/20131229_145539.jpg.html
Check out my screen build thread and thanks again for all your help even if you didn’t know you did.
Discussion Starter #951
Thanks cw5billwade, so you enjoying the CIA approach? Has worked well for me.
Off to check your screen thread.
I really love it and with the AE-8000 and automatic format it is sweet. I have 2.40:1, 1.85:1 and 16x9 formats saved in memory. I have my automatic adjust set for 2.40:1 and 16x9 when I watch 2.35:1 it selects 2.40 format automatic so there is no issue sine the formats are so close the image is just taller. But when we watch 1.85:1 it selects 16x9 and makes bars top bottom and sides so I select the 1.85:1 format manually. the Constant Image height is in a word awesome.
Brad,
Were you ever able to get measurements on your columns...I see how you built them now after looking through your thread a few more times. I'm just curious what your width was and the depth at the top and bottom of the columns? Once again, I appreciate you sharing your incredible theater!
Discussion Starter #954
Ah right, lens memory, nice. I'm still using an RS-20, so no lens memory for me. Since I mostly watch from HTPC using XBMC, I have it set up to do digital shrink on 16:9 / 1.85:1 titles, and 2.35/2.4 untouched, so also no adjustment needed, except when using a Blu-ray Disc.
Originally Posted by reb162  /t/1250265/pimp-my-garage/930#post_24440099
Brad,
Sorry, I forgot to measure, so thanks for the reminder.
The front columns measure 6" deep x 18" wide at the bottom, 12" deep x 18" wide at the top. But since the wall panels between the columns + furring strips are 1 1/2" deep, they only extend 4 1/2" deep at the bottom and 10 1/2" deep at the top.
The side columns are 7" deep x 18" wide at the bottom, 12" deep x 18" wide at the top - 5 1/2" deep at the bottom, 10 1/2" deep at the top after the panels are in place. Why different than the front columns? I think I may have measured wrong and didn't notice, or had to adjust the height (shorten) to account for the riser height. Don't copy that part lol. Anyway, not noticeable in the room.
The "face panels" (covered with black speaker cloth) are 15" wide, to fit between the side 2x2 framing.
In the rear, there are "corner columns", just because of the way the room is laid out - having them inboard on the back wall wouldn't work due to the placement of the rear entry doors. So they are kind of oddball, match the overall look of the side columns, but not an exact match. The "face panels" are 19 1/2" wide, and the "sides" are 3" deep (top and bottom - not tapered like the other columns), go back at a 45 degree angle, so they are perpendicular to the side and back walls.
Let me know if that doesn't make any sense, or if you think of any other questions.
Hey Brad guess where I got the idea for my columns as well.
I based the column on the idea to have a 12” deep speaker in them so I made a shelf for the speaker and attached it to the wall. Then I framed the columns like you did with 2x2s. The rear columns are square so 12” from the wall x 18” wide I have 3” of rear wall treatment they come to 9”x18”. Based on the location the side columns differ at the bottom like yours the riser 6” center column 7” stage 6 1/2" that way all the angles were identical at the top.
http://www.avsforum.com/t/1468993/the-retirement-dream-home-theater/150#post_23484542
http://s629.photobucket.com/user/cw5billwade/media/theater/20131229_145142.jpg.html
Discussion Starter #956
Love it! Off to go catch up on your build thread...
  • Like
Reactions: Mfusick
Looks like I'm bringing this back from the dead , I don't know how I haven't seen it before , especially since it looks like we live close enough for me to hear your subs . Beautiful theater man. I don't have the space for a dedicated theater , but just got my first PJ and may poach a couple of your design ideas to make my living room a touch more "theater like" . If you ever do demos or meet and greets with any of the forum members , I would love to experience a real home theater , let me know how to get an application. Thanks for sharing your build
Discussion Starter #958
Sorry for my belated reply acras - thanks for the kind words - have you run across the LA Area HT meet thread (http://www.avsforum.com/forum/61-area-home-theater-meets/727555-los-angeles-home-theater-group-meet.html)? Quite a few locals get together from time to time to talk HT and share their theater builds. I'm about due to host, at least once the weather cools off a bit and/or I finally get an A/C unit installed. Check out the LA thread, introduce yourself - and if you just feel like coming over, send me a PM.
Thanks for the heads up , I didn't know about the group, I'll check it out. I really don't want to impose , thank you for the kind offer. I'll check out the group and start imposing through there :rolleyes: . It's going to be a LONG time before I can host , and even then it would only be for a group of maybe 3 squeezed on my couch, watching a Benq w1070 , but I am looking to make the most of what I have , and appreciate the amazing spaces you and many others have created . They are all giving me ideas and inspiration for my space.
Thanks again
Brad, do you have better photos of the side panels on your false screen wall? It appears from the dark photos I see that the side panels actually angle in towards the wall instead of going straight across. Did you need to do this to make room for the bass traps? Can you show a photo of how you keep the side panels in place and how they attach on the side wall and at the false wall? I like the minimal framing of the false wall with the open space on each side...I need this since I need to access a circuit panel on the end of my false wall but can't figure out how you attached the end panels with that minimal framing. Thanks in advance.
