Status
Not open for further replies.
1 - 5 of 5 Posts
Hi,
Does anyone have the Pin Out diagram for the special 7 pin S-Video - Component adapter that comes with the X1?
I want to know which of the component RCA plugs correspond to which of the 7 pins in the special S-Video adapter. If no one has this information, can anyone tell me how I can go about getting this information.
TIA
All you need is the connector and a multimeter. Touch the pos and neg on the RCA terminals and check which pin on the SVideo side has continuity. I'd do it, but I'm getting ready to go see X-Men 2 at the theater. If no one does this by tomorrow, I'll have to find the adapter and give it a go.
Matt
S-VHS plug
1 2 3
4 5 6 7
Component
1 =
2 = G (center)
3 =
4 = R (outside)
5 = R (center)
6 = B (center)
7 = B and G (outside)
Pat
So can we assume that for Svideo:
1=chroma
3=Luma
4=chroma ground
7=Luma ground
That would mean that inside the PJ, Svideo and Components are taking 2 very different paths, so we should be able to make a cable with both connections and switch the sources with the PJ's menus.
Anybody to concur ? KBK ? Bob Williams ?
Pierre
1 - 5 of 5 Posts
Status
