1 - 2 of 2 Posts
For sound isolation not really.
That being said I did end up using the Roxul Safe and Sound myself. Burning/melting wise the Roxul has a much higher melting point the the pink stuff.
Not sure about the pink stuff but the Roxul also cuts fairly easily.
Go with whatever you are comfortable with or can get cheaper.
The important thing is to fill that empty wall cavity to avoid a resonating effect you would get from an empty wall cavity.
1 - 2 of 2 Posts
