Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
Last night, watching a movie on the Pio, suddenly a message flashes in the middle of the screen "Shut down", and I did. So, I wait about 5 minutes, (worried), and turn it on, and everything is fine. Today, it's working just fine. It's about 18 months old and never had a problem.
Anyone seen this? I couldn't find any mention doing a slow search.
Anything I should do? I checked fans and they seem fine.
· Registered
Was the picture still present when the message came on? When I use the VGA input on my 433CMX, after just a couple of seconds of the PC being off or disconnected, the 433CMX will say something like 'NO SIGNAL DETECTED' then 'POWERING OFF.' An intermittent cable, perhaps?
· Registered
Discussion Starter · #3 ·
No, the picture was just fine. This was a black box with message in the picture (bottom of the screen.) Picture stayed fine until I turned unit off, and was fine when I turned it back on. Cables are good BNC component. No problems there.
Thanks for the ideas, though.
1 - 4 of 4 Posts
Status
