*Updated 4/7/08 - Updated Movie mode settings: contrast, sharpness, pure cinema; Edited PS3 24hz setting*
These settings are intended for HDMI inputs only. I've chosen to use Movie mode as it does not drive the panel as hard as User mode, resulting in less PWM noise (yielding a "cleaner" image). Use these settings for your Pio 5080, PS3, Xbox 360, Dish receiver and the results should be satisfying.
1) Under Options -> HDMI input on your 5080; make sure Video setting is set to Auto.
2) On the Xbox 360, under Display settings in the System blade, choose Standard Levels. Also set your 360 to output 1080p.
3) On the PS3, set output to 1080p and the following settings like so...
Under BD/DVD settings, Force Y Pb/Cb Pr/Cr, NOT Auto or RGB...
Under Display settings, set RGB: Limited, NOT FULL...
Superwhite: On
BD 1080p 24Hz Output: Auto (I set this to Off which seems to minimize stutter/judder)
4) I set my Dish Receiver to output 720p as I watch a lot of 720p program material.
5) Set your 5080 settings like so...
Main Menu:
AV Selection: Movie
Contrast: 38
Brightness: 0
Color: -2
Tint: 0 (middle)
Sharpness: -6
Pro Adjust
Pure Cinema
Film Mode: Off (On for 1080i material)
Text Optimization: Off
Picture Detail
DRE Picture: Low
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail
Color Temp: Low
CTI: Off
Noise Reduction
3DNR: Off
Field NR: Off
Power Save Mode: Off
Orbiter: On
6) These settings result in light output around 39 foot lamberts on the 5080. I have a light controlled room, so these settings may be a bit too dim for some. Just increase the Contrast setting a bit if need be. But at a setting of 38, you will be minimizing IR.
Superwhite: On
Main Menu:
AV Selection: Movie
Contrast: 38
Brightness: 0
Color: -2
Tint: 0 (middle)
Sharpness: -6
Pro Adjust
Pure Cinema
Picture Detail
DRE Picture: Low
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail
Color Temp: Low
CTI: Off
Noise Reduction
3DNR: Off
Field NR: Off
Orbiter: On
