I have a Pioneer 84Txsi that I am using as my processor for my home theater.
I have 4 sources hooked up via HDMI. PS3, Sony BDP-S1(blu ray), Toshiba HD-D1 (HD Dvd) and a Directv HD DVR. Pioneer hooked up via 50ft monoprice HDMI cable to a Sony "Pearl" projector.
It seems to pass the signals fine. Even 1080p but occasionally it will get "stuck". The screen will show the picture fine on the top half but the bottom half will flicker and have snow. If you turn the receiver off it will usually correct itself.
I assumed it was because of the length of my HDMI cable to my projector but I just installed another Pioneer 84 at a friends house and he is getting the same picture problem. But the kicker is we only used two 6 foot cables. That should be well within spec.
Any ideas? Has anyone else experienced this? Has anyone talked to tech support?
