Status
Not open for further replies.
1 - 4 of 4 Posts
I installed the drivers/patch for my Pioneer DVD-116 16X DVD-ROM drive for the silent mode, but how to I enable it, or is it automatic?
will this work for 115? its noisey as heck. I also have the older 10X model which is so much more quieter. OT but do you think plextor will ever make a DVD drive, I found the drive to be so quiet when running its hard to believe its on!
Vasim,
It "kind of" works with 115, though I'm not sure with mine. It seems the effect of the utility only lasts until you restart Windows, but I'm not 100% sure on this.
What I've found to reduce noise and vibration on the 115 is BIOS v1.33, found on this same page with RPC-1 (code free).
1 - 4 of 4 Posts
Status
