Status
Not open for further replies.
1 - 3 of 3 Posts
I was burning a dvd-r the other day with my Pioneer DVR-104 and Prassi Primo DVD locked-up so I had to crash it. Ever since then my Pioneer drive will only read CD's and CD-R's. It will not read any DVD's including commercial DVD's of movies you buy at the store. The problem is whenever I put a DVD in the drive the Pioneer does not recognize it at all. The Windows explorer shows that nothing is in the drive and ask me to insert disc.
I tried uninstalling the drive but no luck. I did just recently upgrade the firmware via the CD that Pioneer sent to me, though I'm not sure if this has anything to do with it.
Please help
Thanks in advance,
Rick
I don't know if this will help, but I had this exact problem with my laptop DVD drive. It was very persistent. I cleaned the laser pickup with a q-tip and the problem went away completely.
Hope that helps.
Bob
1 - 3 of 3 Posts
Status
