1 - 20 of 594 Posts
Hello Everyone, My name is Chris Walker, I am the Manager of New Technology for Pioneer Electronics. Everyone at Pioneer loves this site and Pioneer has decided to go ahead and try to answer some of the questions that the enthusiasts on this site may have regarding Pioneer's Products. My focus at Pioneer is product planning for AV products (DVD, DVD Recorders, AV Receivers, Blu-ray, and HTIB). As you can imagine there is some information that I may not be able to share due to timing and competitive issues, however I will do my best.
If I fail to respond to certain questions in a timely manner please do not take offense. Sometimes I have to wait for answers from Japan which can take some time.
Also, please do not take offense if I cannot answer a question due to product introduction timings as well as competitive issues.
I am looking forward to trying to answer any questions you might have.
Chris Walker (WalkamoHB)
I am currently looking to buy the 6th generation Pioneer Elite plasma. I was interested in the PRO-1130HD but I will not need the media box or speakers. Is there a "Monitor" version of the 1130?
The current 5th gen monitor model number is 1010HD so can I expect to see a 1020HD?
http://www.pioneerelectronics.com/pn...753531,00.html
Premium Member
Chris,
Welcome!
Questions:
Might Pioneer upgrade MCACC to include correction of time domain behavior as does Audyssey MultEQ and, I believe, HK?
Also, how about full correction of the subwoofer channel, arguably the most important in improving sound quality.
Along this line, something that no one has is a user-selectable lower limit frequency to match the sub's capabilities (HK comes closest a sub size selection, but results are hit-or-miss).
Or, might Pioneer ever offer MultEQ?
Another EQ feature I'd love to see is at least two memories for different EQ setups for those of us with different music listening and movie viewing locations.
Thanks very much
P.S. I thought from the thread title that someone had a question; little did I suspect we were going to be treated to Pioneer pruduct *answers* from an actual Pioneer representative; perhaps you can edit the title so people don't unknowingly miss out.
Hi Chris,
We have heard through the "grapevine" that the recently released 74TXVi has Burr Brown DSD1791DBR DACs. Can you confirm this?
Also, can you tell us what OpAmps are used in the 74TXVi?
Lastly can you confirm and maybe explain what type of amplifier section is in the 74TXVi? Class AB, Class D? Does it use MOSFETS or Bipolar transistors, etc....?
Patrick
Discussion Starter · #7 ·
Right now just the 1130 and 930HD models. We are working on our monitor plans right now.
Chris
Great receivers. Though I can't afford an Elite at the moment, I know an elite will be up there when I upgrade. Pioneer should look into implementing video processing in some of their receivers like the Harman Kardon 7300, and Denon 5805. Though those receivers use top of the line Faroudja video processing, I think this could be implemented in even the lower end lines by using by using lower end processing chips used by dvd players (or something to that effect).
One thing I find lacking is the on screen display on pioneer receivers. Showing something as little as volume control can mean a lot for many users. The OSD shouldn't be limited to just set up.
Discussion Starter · #9 ·
Originally Posted by noah katz /forum/post/0
Chris,
Welcome!
Questions:
Thanks very much
Hi Noah, the new MCACC feature in the 72 and 74 will solve both the time issue as well as the Subwoofer issues.
Phase control addresses the delay in bass from the LPF in the receiver as well as LPF in the subwoofer. As you can imagine this delay causes major phase problems in the audio. I will post some pre and post Phase Control delay charts in the detailed product information section our custom install section of our website (Next day or two)
Subwoofer channel correction has been greatly improved with the Standing Wave Control with our new VSX-74 and 72 receivers. You simply place the microphone in 3 different locations in the room. I cannot go into exactly how this is done (since we are the only ones doing this right now), but I will post some pre and post charts in the detailed product section of the custom install section of our website. Next day or two)
As for having a couple different MCACC memories, the 72 and 74 have 6 different memories for differnt seating locations.
Chris Walker
Discussion Starter · #10 ·
Originally Posted by avaholic /forum/post/0
Hi Chris,
Patrick
Hi Patrick,
Yep, that is correct. There are 4 of them (1 for each set of two channels) 113db dynamic range. That is 1 db more than the famous PCM1704.
The OpAmps that are being used are UPC4570 from NEC. These are the same that were used in the VSX-54 and 56.
The amps in these new receivers are Low Energy loss Class AB amps(Bi-Polar) (We call them Direct Energy). They very unique in there design. We should have a detailed explanation of them on the website in a few days. I think everyone will be pleased with the sound.
Chris Walker
Discussion Starter · #11 ·
I agree with you regarding video processing, the VSX-74TXVi and the 72TXV, are the first to have any kind of video processing at all. There is no scaling or IP conversion, however there are video adjustments (Color, Brightness, etc...) for each input. This way you do not have to keep making adjustments to your television. Simply setup the video for each source connected to the receiver and leave your TV to one input.
The OSD is a little better then in previous years and our goal is to continually improve it.
Chris Walker
Discussion Starter · #12 ·
Originally Posted by Tom Grooms /forum/post/0
Spill the beans on the new flagship A/V receiver. And thanks for always taking care of your dealers with the deluxe accommodations program.
Sorry Tom, a little to early to discuss new Flagship at this time. But I will let you know as soon as I can.
I am glad you are pleased with the accomdation program for dealers.
Chris Walker
Probably a stupid question but I just purchased the 1015tx and if you read many of the threads you will find that many people loves this AVR. I love mine except for 2 things.
Is Pioneer releasing a Silver version is the US Market?
It seems to be a little quiet on the volume side, I understand this has a lot to do with speaker efficiency and room accoustics, but I seem to listen to music between -10dB and -3dB. This seems to be a little on the high side of the volume scale. I would not consider this volume to be ear piercing or anything either.
Hey Chris,
This is my first post here but i have been following this forum from a few months now. My question was in regards to the difference between the 72tvx and the 74tvxi. I know that there are some obvious differences between them such as the i link ports, the usb port, etc. My main question was in regard to the differences in DACs, OpAmps, and the Power supplys between the two new Elite receivers. How exactly is the extra 10 watts per channel rating achieved on top of the 130 watts per channel the 72tvx is rated at? Also how was the weight reduced from the 54tx to the 72tvx [difference in shielding, power supplies, etc?].
Thanks so much for taking the time to clear my doubts.
Originally Posted by WalkamoHB /forum/post/0
Hi Patrick,
Chris Walker
Thanks for the quick response Chris! This is a Great idea to start this thread BTW!!
I look forward to the Amplifier explaintion.
As far as the OpAmps go I know someone who has the service manuals for the 55TXi/56TXi and it says the OpAmps used in those models are the NJM4565, not the UPC4570.
So I guess they are different. Do you know how they differ?
Patrick
Premium Member
Chris,
"Phase control addresses the delay in bass from the LPF in the receiver as well as LPF in the subwoofer ..."
If this is in response to my question about time-domain correction, it wasn't phase I was referring to.
Audyssey, for example, claims that MultEQ will correct a sidewall reflection by generating its inverse to cancel it.
"Subwoofer channel correction has been greatly improved with the Standing Wave Control with our new VSX-74 and 72 receivers."
How low in freq will it correct?
Also, will it attempt to fully correct modal peaks? I have an HK 635 which improved my bass range a lot but it's obvious it didn't fully correct the peaks, and others have made corroborating measurements to that effect.
"As for having a couple different MCACC memories, the 72 and 74 have 6 different memories for differnt seating locations."
Great!
Thanks, Chris
P.S. You did tell your boss this would be a full time job, right?
Discussion Starter · #17 ·
Patrick
There are two different OpAmps being used. I will detail each one below.
For LPF of DAC=> BA4560RF (supplier: ROHM)
For Flat amplifier section => UPC4570 (supplier: NEC)
Chris Walker
Discussion Starter · #18 ·
Chris,
Great!
Thanks, Chris
Hi Noah, sorry for the misunderstanding. I have sent an email off to Japan to get a clearer answer to your question regarding time domain correction.
As far as Standing Wave Correction, I need to get an exact answer from Japan as well. However I am adding an image of exactly what the circuit does. I will try and get some actual measurements as well.
Chris Walker
Discussion Starter · #19 ·
Chris,
Great!
Thanks, Chris
Noah, thank goodness for the time difference in Japan. I received an answer regarding how low in freq that the circuit will correct (62.5Hz up to 250Hz)
Chris Walker
When can we expect the new 2006 models to show on the Pioneer website? I am interested in the full spec sheet of the VSX-74TXVi receiver.
1 - 20 of 594 Posts
