Status
Not open for further replies.
1 - 5 of 5 Posts
is this unit basically the same? besides the warranty and look of the frame? are the electronics the same as the 433 with the 5002 card? pq wise the problem i have is that i have seen the pro800 on display and it looked great.. but no one has a 433 on display for me to look into. i just want to make sure i am buying the same product basically thanks
Pro 800 HD = 433cmx + glossy frame - 1 "extra" year of warranty + a video card (basically a PDA-5002 without the PC-only DVI connection...).
I saw lots of 4330s, with their Sharp-provided media receivers, but it wasn't until I saw the Pro 800/1000s at the same store as the 4330/5030s that I decide to "pull the trigger" on the 433cmx.
I am still VERY happy with that decision.
-- Gary
how much better did the pro800/1000s look? less 'noise' than the 4330/5030s?
MMAfia
IMO, the picture on the 4330/5030s looked a bit "washed out" in comparison, no matter how much I played with the controls. The 800 and the 1000 both gave more of a "looking through a window" effect. The colors seemed to jump out at you.
-- Gary
Discussion Starter · #5 ·
I'm an SOOOO close to pulling the trigger based on your review of the unit , not i just wonder how it would look with a regular satellite signal going to it at 480i? does it automatically boost the signal to a better one or does it handle the job good with just that.. is it grainy and dull looking with a weak signal? I'm really close to calling dell and Gary can you look at the cable post from last night tell me if i have the right idea? thanks so much for you help :D
1 - 5 of 5 Posts
Status
