1 - 3 of 3 Posts
All:
Apologies if this has been asked and answered but a search didn't turn up anything.
In any event, I bought one of these 2d hand for the purpose of using in my apartment while undergoing a remodel at my home. I noticed early on that the device would occasionally power of and then back on randomly. It went away but then it turned off today and doesn't respond at all. I can remove the power cord for a period of time, etc., but to no avail.
My first question is whether anyone else has seen this issue with this device. Second, if so, is there a cheap fix? I don't want to spend any large $$ on this because the cost might exceed what I paid and I've only got another 4 weeks before I get back into my house and can re-install my Cary.
Any comments would be most welcome.
Thx.
John
Did you ever get an answer to your question about your VSX-31?
I've had this receiver for a couple years and am just encountering a similar issue as you have described. I have been getting it powered on and after a couple seconds it will power off and then back on, repeating this non-stop until I pull the power cable from the back.
Let me know if you can.
1 - 3 of 3 Posts
