Have always owned top of the line Denon receivers including the 5800. Contemplating the 5803 upgrade, but also decided to look around while I was at it. Have seen very little here about the 49TX, but it appears to have some very favorable reviews including the ones attached below and like the 5803 is THX Ultra2 certified. It also stacked up very well vis-a-vis the 5800 in the Sound & Vision lab testing actually producing a better all channels driven power measurement than the 5800 which carries the higher power rating on paper.
Appreciate any thoughts on the 49TX vs. 5803. Is the 5803 the hands down way to go or is the 49TX a serious and viable contender for anyone considering the 5803?
http://www.dvdphd.com/reviews/pionee...x_review.shtml
http://www.soundandvisionmag.com/pdf...ioneer_lab.pdf
Mark
Mark
