Originally Posted by chadmak09 /forum/post/14378957
Guys,
I have been getting alot of PM's from people who are stuck between the non-elite (5020/6020) and the Elites (PRO-111FD / PRO-151FD).
This is because I have had the PDP-6020FD for about a month or so and decided to sell it and buy an elite Pro-151FD.
The PM's I get are all about the same. What are the differences, and is it worth it.
I have compiled the list of differences (settings / features).
(I probably have forgotten a few things so please let me know and I will add it to the list if I did.)
So here is my answer:
Elite (111/151 OR 5020/6020)?????
It depends on what kind of person you are really to choose between the elite and 6020.
If you want the best color accuracy possible and like to have a number of settings at your disposal, then the elite is for you.
If you are the type of person who wants great color depth, black levels, contrast, not the best color accuracy (but very good),etc. and doesn't place alot of importance in being able to tweak the set to perfection, then the non-elite is for you.
If you think that you may be one of those who doesn't really want to dial in the picture and will use optimum mode most of the time, Then go with the non-elite.
IMO, If you are going to use optimum mode as your main setting then you do not need the elite because the non-elite also has it (just without the color sensor).
Here are the settings/features the Elites (111/151) have:
Settings:
1. Brighness
2. Sharpness
3. Color
4. Contrast
5. Tint
6. A/V selection (Optimum/Performance/PURE/Movie/Sport/Game/Standard)
7. Pure cinema selection (Film mode ON/OFF, Text optimization ON/OFF)
8. Intelligent mode (OFF / MODE1 / MODE2)
9. DRE (Off / HIGH / MID / LOW)
10. BLK LVL (ON / OFF)
11. ACL (ON / OFF)
12. Enhanser mode (1 / 2 / 3)
13. GAMMA selection (1 / 2 / 3)
14. Color temp (Manual/LOW/Mid-LOW/Mid/Mid-High/High)
15. CTI (ON / OFF)
16. Color management (R / Y / G / C / B / M)
17. Color space (1 / 2)
18. 3DNR (OFF / HIGH / MID / LOW)
19. Field NR (OFF / HIGH / MID / LOW)
20. Block NR (ON / OFF)
21. Mosquito NR (OFF / ON)
Features:
1. Color sensor (not availible with non-elites)
2. Backlit remote (not availible with non-elites. But you can order the 151 remote from Pioneer and use it on your 6020)
3. Elite color filter. (not availible with non-elites)
Here are the Features/Settings the non-elites (5020/6020) have:
1. Brighness
2. Sharpness
3. Color
4. Contrast
5. Tint
6. A/V selection (Optimum/Performance/Movie/Sport/Game/Standard/NO PURE MODE)
So the big question is does the 6020 have enough settings/features for you?
Either way you go you will have an awesome set.
The 6020 is beyond words, but the elite breaks all boudaries IMO.
So it is really up to you if the price difference is worth it. In my case it was.
-Hope this helps you. Let me know if you want more info!
-Chadmak09
