1 - 5 of 5 Posts
Hello all, I just bought this Kuro NiB and loving every second of it(upgraded from an old tube TV). Anyway, after setting it up and watching a couple things I went around back to check the heat levels. I was quite surprised as to how not hot it was, but I noticed an issue. The small fan mounted on the inside of the TV wasn't spinning at all.
I dismissed it as not being hot so i watched something else and went back and checked again, and not spinning. Is this normal, i figured that the fan would be running most of the time to keep it cool.
Anyone have some insight to this? or need additional information let me know ill be happy to oblige.
And by the way keep up all the good work in these forums! they are quite helpful
The temperature trigger point for the fans (there should be several, not just one) to operate is very high.
I'd be much more concerned if the fans did come on.
Discussion Starter · #3 ·
Okay that makes me feel better, would you happen to know the location of the other fans, i just saw the one on the top left of the TV(viewing from the front)
There is another fan in the lower right corner (Viewing from the front)
Here are some pictures of the four corners of the PRO-101FD
They show where the two fans are located.
Upper right corner (Fan #1)
Lower left corner (Fan #2)
Upper left corner
Lower right corner
1 - 5 of 5 Posts
