Do yourself a favor, get the Pioneer.
Do it now. Don't go back. If you have the money. Plasmas are much better then rear projection, and I own both.
A clearer picture. A more accurate picture. And a more pleasing picture. (Well the last one is an opinion ^_^ )
The fact that it's flat and looks utterly awesome when it's turned off is a bonus. 1080p is wasted at this TV size at normal seating distances, and you won't have to deal with silk screen effect. Not to mention Bulb Replacement... ugh.
The only advantage a Rear Projection has is that absolute black is a bit darker. But to achieve this you might have to use a dynamic iris, which causes black level instability and shadow detail in scenes with bright and dark areas.
Green blob problems anyone?
