1 - 9 of 9 Posts
I have a Pioneer Receiver (VSX-819H). It was working fine for about 3 years. Recently the TV picture went out. I also noticed the HDMI light was blinking on the receiver. I tried a new HDMI wire, but didn't work. I bypassed the receiver and connected the components directly to the tv via HDMI and they work fine. So I know it has something to do with the receiver HDMI input or output. Pioneer told me to reset the receiver which I can't get to work. I don't get the reset option when holding Band and holding the Standby button for 2 seconds. Does and HDMI part on these receivers go bad? Any advice?
Premium Member
Yes, HDMI boards can go bad as they are very sensitive to voltage fluctuations (especially with thunderstorms nearby). Unless Pioneer's reset procedure is different from Denon's, for the reset procedure to work, you would press/hold those two buttons on the front panel of the AVR while powering ON the AVR (ie. you don't just press them while it's already ON).
Discussion Starter · #3 ·
Thanks - I figured out how to reset. Turning off the multi zone display allowed the reset to come up. So I reset it but still have the same problem with HDMI blinking and no picture. We didn't have a thunderstorm when it went bad. Maybe too much dust though. I guess I can connect HDMIs directy to the TV and wire just the sound to the receiver by component wire. Hate to add wires and lose quality though. Will pioneer send me a new HDMI board? Any other suggestions?
Premium Member
No, they don't just send you repair parts. If the AVR is still under warranty, then give Pioneer a call and see what they can do for you. If they determine it is the HDMI board that is defective, you'll likely have to ship it to a Pioneer repair facility. Note that should you have to go to optical/digital coax, it's doubtful you would be able to tell any difference in audio quality listening to the higher bitrate lossy DD/DTS audio tracks on BDs over optical/digital coax vs. listening to the HD audio tracks over HDMI.
Hello,
     Were you able to solve your problem and if so how?  I have a VSX-1121 and I recently started experiencing a similar problem.  I am trying to run an Apple TV through my AVR to my TV.  When I attempt to do so, the HDMI light on the pioneer blinks every 5-10 seconds or so, but nothing is ever displayed on the TV.  If I connect the Apple TV directly to the TV and run audio out from the TV to the AVR, then it works okay, but I only have RCA outs on the TV so it's all stereo.  I'd prefer to utilize surround sound.  Any feedback will be appreciated.
pioneer vdx-44 hdmi blinking
I have simular problem. My Pioneer elite vsx-44 failed. The hdmi led is blinking and will not turn back on at all. This is after I have troubleshooting and now it is back in the box ready for the afterlife. I paid about $500 for it. Its now a boat anchor after 2 years and 1 month of use. Yup, just past the warranty :rolleyes:. Sad that my older pioneer receiver, turntable, cassette and reel to reel still work after 30 years. New stuff is not same quality.
I need to know if there is a Hdmi card I can install or this is a simple solder of parts which Im capable. I see and hear this problem but most have been under warranty. Has anyone done a DYI fix? Will pioneer sell parts? thanks for help
Hi,
Did you finally solved the issue with your receiver?
1 - 9 of 9 Posts
