1 - 5 of 5 Posts
I have the Pioneer VSX-1020-K connected to the LG BD-570 blu-ray player and a Samsung PN58C500. I have it all controlled by the Harmony One. Whenever I turn on the watch DVD command, which turns on all three and switches the receiver to the BD setting, it works fine for about 5 seconds. Then the receiver switches over the TV/SAT station. It will do this if I use the Harmony One, the individual remotes, or do it by hand. Has anyone else run into this issue and found a fix for it. All of these devices are new and this is the first time they have been used together.
yes, turn off hdmi control (kurolink on your avr)...
it's working as designed...
yes, it's in the manual...
1 - 5 of 5 Posts
