Hello,
I am considering buying the new Pioneer VSX-01TXH A/V Receiver.
I looked at the User Manual on the website and on page 2, there is a notice Ventilation Caution. After reading this, I am a bit disappointed.
The paragraph says to leave 60cm at top, 30cm each side and 10cm rear.
Probably like many other people, I have a furniture in which all my devices are installed. Based on how the furniture is made, I can provide the 10 cm rear but not the 60cm at top and 30cm each side. Also, there is a window door on the front of the furniture.
Is this notice at this point important? Do you own this Receiver or similar receivers from Pioneer installed it in a furniture?
Do you think I can safely buy the receiver or I should stop all my plans?
Thanks for your help.
