1 - 2 of 2 Posts
Ok never had an AV receiver before so sorry for my ignorance. I have read through the instructions and it says it should pick up FM radio signals without a Antenna. Which it does not do at least for me. The little Antenna that came with it seems to be for AM radio. What type of connection is that FM radio connection anyway? It doesn't look like a F-Connector so what wire would I use to run from an antenna to the receiver? Here is a picture of the back.
http://www.pioneerelectronics.com/St...ck%20Panel.jpg
What is the best route to get FM radio stations. I will be planning to buy the HDTV Antenna from Monoprice eventually will that work as a FM antenna? If not what is a decent antenna for me to buy? Thank you for any help you can provide.
1 - 2 of 2 Posts
