1 - 3 of 3 Posts
Hi can anyone help me - I have 2 issues about a Pioneer VSX-817 AV Receiver.
1. I am using Wharfedale Diamond 9.1 Front Speakers and using the bi-amp functionality on the VSX-817 to drive them. By using this functionality I have connected the back surround speaker outputs as well as the fronts to drive the speakers. I assume this means that I can't use the Zone B functionality of the VSX-817??
2. The Wharfedale Diamond 9.1's are 6 Ohms and I have set up the VSX-817 accordingly. I want to connect 8 Ohm Zone B Outdoor speakers. Can I do this without affecting the system? As far as I can tell I can only set up the impedance on the VSX-817 for all channels - not for separate ones?
Any help would be appreciated - pretty new to this game!!!
Dave.
- eliminate the bi-amp... it buys you nothing...
- set avr back to 8 ohms... if it shuts down (i.e. goes into protection) in 8 ohm mode, all you are doing by setting it to 6 ohm is limiting the current so that it doesn't shut down...
- it may have difficulty driving b/zone speakers while the main zone is in use... you are asking quite a bit of the power supply in that case...
1 - 3 of 3 Posts
