The PS10 is going to do NOTHING for your system with M70's...
Otherwise, there won't be any issues.
Originally Posted by HTNoobie2011 /forum/post/20838874
Also do you think there will be any major issue when running 5.1 mixing the yamaha's into the rear channel (timbre, voice etc) ? I already have them so Id rather just keep them for some use and in the rear channel I figure it wouldnt be as significant in timbre and vocals as the fronts and center (Polk)
Originally Posted by schan1269 /forum/post/20839341
There is nothing wrong with your present Yamaha for rear duty. If one day you decide they aren't enough, replace them. The Polk Monitor is so cheap right now, lots of people are buying them. They will probably be plentiful on the used market for years.
And yes, the PS10 is a waste of time. Before spending $100 on it, peruse Ebay and Audiogon...for that matter, Craigslist for a subwoofer near you in the $150 and under range.
