PIP Problems
242 Views 0 Replies 1 Participant Last post by  Steve Ford
Just yesterday I finally received my Hitachi 42" plasma TV. I am very pleased with the product--with one exception.
I am feeding the cable signal (Comcast cable) to the Motorola CATV box, then from there to the TV via a DVI-D cable. This input is "INPUT 1."
Using a splitter in the cable line BEFORE the CATV box, I am also running a short coax cable jumper to the TV "CABLE IN" connection. I understand that I won't receive the digital channels that must be decoded by the CATV box on this input, just the analog channels.
When I attempt to use the PIP function, INPUT 1 displays, but the other box is black. When I try to select the black box, I see the message "No channel detected," or something to that effect.
If I am reading the Hitachi manual correctly, I *should* be able to view INPUT 1 (DVI from the cable box) on one PIP screen and the analog CABLE signals on the other. Or have I misunderstood?
Thanks . . . Steve
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
