I'm a newbie in the front pj world, and needy of assistance.
I have a Sony HS20 w/ a long throw lens. I was planning to ceiling mount the projector, but I found out that I don't have the right to drill my ceiling. So I hope to go w/ plan B: sit the projector on my high bookshelf. I calculated the distance and screen dimensions based on the Sony calculator and it works out both distance & height wise for a 92" diagonal 16:9 screen 17.5' away. That is, if the lens is inverted (pj upside-down). Problem is- I cant find a mount that hangs a projector and itself sits tabletop. Probably not much of a market for this sort of install. I hope someone can point me towards a mount that can accomplish this... or perhaps suggest some materials for a DIY mount based on a comparable installation. Thanks.
