I assume you are looking for a good online dealer? If not, then you can disregard the next paragraph...
IIRC, Rotel has a very strict distribution policy and does not allow mail orders via the web or otherwise. To purchase new, you have to purchase from your local authorized Rotel dealer.
But in any event, check out Rotel's Website to find the dealer nearest you in North Carolina.
If you're buying used, try Audiogon .
Good luck!
RR
Good luck!
RR
