Status
Not open for further replies.
1 - 1 of 1 Posts
I want to build a HTPC this summer. I got a few questions:
I plan to have a cable splitter split the signal from the source. one feeds into the tv, the other feeds into the tv tuner card on the HTPC. My problem now is how I should connect the HTPC to the TV to get the best picture? Assuming I can afford to get an ATI AIW.
I am sort of a newb at HTPC, the above way, from reading through the posts, doesn't seem to be the best way to configure the inputs and outputs. What would be a good way? The main reason I wanted to do it the above way is that I didn't want the TV to be dependent on the HTPC, I still want it to be able to function by itself (function, I mean by getting a cable source and display it); I don't want to turn the HTPC on everytime just so I can channel surf using the TV Tuner card.
1 - 1 of 1 Posts
Status
