Status
Not open for further replies.
1 - 1 of 1 Posts
I was just about to pull the triger on a Panasonic TH42PX20UP for a bedroom application but it will not fit on the lift in the cabinet. The travel distance of the lift is too short to be able to lift this plasma to the appropriate height. My only alternative is to increase the size of the cabinet and put a lift in that would support a 60" plasma. This added cost and size is not feasible.
My question is should I look at the Pioneer PDP4340 or the 42" Fujitsu. I need a consumer version with integrated tuner and speakers. This going at the end of a bed.
I also thought about scaling the plasma back with the Panasonic TH42PA20UP.
Typical viewing distance 7'-8'. Mostly SD Directv and DVD.
Any thoughts?
CGM
1 - 1 of 1 Posts
Status
