Well I've finally made the plunge and ordered at 42" Panny Plasma. Little did I know what an ordeal it would be to find the right vertical wall mount.
First, I had no idea how much the Panasonic brand wall mount would cost (over $400!! - what a rip). Second, it's damn hard to find anyone selling the original Panny mount.
So...I'm looking at the aftermarket units that are out there and I'm only seeing one or two (the brand names elude me... I think Peerless may be one) and I'm not all that impressed by the construction. My main concern is the thickness of these things - looks like they add a couple of inches to the plasma so the wall mount will really stick out off the wall quite a bit - my main reason for wall mounting for the cool factor and I don't want the thing sticking out of the wall 5". When one enters the room where the plasma is to hang, the initial view of the set is in profile so I want the thing to be backed up against the wall as far as possible. At this point I'm considering the Panny table stand that I have found for $200.
Whew... OK, so for my questions: What is the best (thinnest) vertical wall mount (for a reasonable price i.e. $200 range) ? Does anyone know where I can buy a factory Panny wall mount that won't break the bank? Anyone have a mount for sale (Panny or aftermarket 42")?
Thanks in advance!
-Kale
Thanks in advance!
-Kale
