Originally posted by Major Havoc
About how high should the bottom of a wall mounted 50" be above the floor? I want to put a credenza below it for the AV equipment, but need to know how much room I have to work with. |
havoc,
went through exact same dilemal i have a heavy center channel and wanted something fairly low to store the components as well as a act as a speaker stand. the solution was a perfect Salamander Designs Synergy Twin20.
with 8' ceilings and sitting 10-11' away, a height of 36" (from the floor to bottom edge of plasma) was perfect. not to tall and not too short. still looks like a huge picture on the wall without cramping one's neck to look "up." if you have higher ceilings, adding 5-10" to 36" wouldn't be bad - make sure your wall bracket has a tilt feature so you can experiement.
pictures are available by clicking on my gallery above...
