1 - 3 of 3 Posts
· Registered
Hi everyone,
I have a samsung 5064 plasma!
I am watching tv and somehow there is in the right hand corner a light square with a white well lit number 2 inside of it.I can't figure out how to get this off my tv.Do not know how it got there either!
Any ideas!!
Mike
· Registered
My cable box has the option to display the "info" or "channel" info all the time (as opposed to only when you are sifting through the channels). You may want to check this setting on your cable box in the advanced menu options.
1 - 3 of 3 Posts
