1 - 7 of 7 Posts
I would like to play .mkv files with DTS using Windows 7 (64 bit) Media Center, and be able to output DTS to my receiver. So far I have been unsuccessful - audio is sent to the reciever decoded to stereo. I tried ffdshow, AC3 Filter, DivX codecs, SPDIFer. I can play the same file using Windows 7 Media Player, and DTS is sent to the receiver.
If someone has a definite answer, please let me know the formula to DTS for .mkv in Media Center 7.
remove/uninstall ALL of the haphazzardly installed codecs on your system.
(AC3Filter, anything DivX, FFDshow, MatroskaSplitter, Haali, manually registered ax files, etc)
Install the Shark007 Win7codecs along with the x64Components addon.
Check Control panel | Sound, under your spdif output, and set the speaker configuration to stereo
Open both of the Settings Application(s) (32bit and 64bit) and choose to use the SUGGESTED settings checkbox.
Go to the Audio TAB and set 'passthrough' on the right. The speaker configuration shoulds be set to 'Same as input'
Do the Audio TAB again (in both apps), but this time, do not use Adinistrative priveleges to open it.
If you have problems with MP4 files with this configuration, go to the SWAP TAB and re-enable Media Foundation.
Discussion Starter · #4 ·
I have a problem with one particular .mkv - it does not play on my HTPC, but it plays on my desktop. Both PCs are Windows 7 Ultimate 64bit, and both have been configured as per Shark007 instructions. The HTPS uses SPDIF passthrough, while the desktop PC uses analog 2 channel to speakers. What could be the issue? Media info shows the following information:
General
Unique ID : 180987559557867926855068338549773304416 (0x8828EFA110A2C5388BF7F3E8A8700260)
Complete name : \\\\LG-NAS\\movies\\Cloudy\\Cloudy.mkv
Format : Matroska
File size : 7.05 GiB
Duration : 1h 29mn
Overall bit rate : 11.2 Mbps
Encoded date : UTC 2010-01-04 19:17:46
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=5, N=20
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 29mn
Bit rate : 8 249 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.220
Stream size : 5.07 GiB (72%)
Title : FraMeSToR's "Cloudy with a Chance of Meatballs"
Writing library : x264 core 80 r1376M 3feaec2
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=2 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=8249 / ratetol=2.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.80
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 29mn
Bit rate mode : Variable
Bit rate : 2 929 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : DTS-HD track
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Dutch Subtitle Track
Language : Dutch
Text #2
Format : UTF-8
Title : English Subtitle Track
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:04:28.184 : en:00:04:28.184
00:04:38.194 : en:00:04:38.194
00:04:47.620 : en:00:04:47.620
00:08:56.577 : en:00:08:56.577
00:14:33.163 : en:00:14:33.163
00:20:30.228 : en:00:20:30.228
00:24:25.589 : en:00:24:25.589
00:30:43.174 : en:00:30:43.174
00:36:29.604 : en:00:36:29.604
00:42:50.109 : en:00:42:50.109
00:46:36.793 : en:00:46:36.793
00:52:43.827 : en:00:52:43.827
00:55:07.429 : en:00:55:07.429
01:00:42.764 : en:01:00:42.764
01:05:43.397 : en:01:05:43.397
01:13:03.754 : en:01:13:03.754
01:17:45.369 : en:01:17:45.369
The PC using anolog should not be set to 'passthrough' in the Shark007 Audio TAB.
go to the Audio TAB in both settings applications (as an admin, and without admin rights) and 'turn off' passthrough.
The leftside speaker configuration of the Audio TAB will detect what you have set for speakers in Control Panel | Sound,
and will automatically set the speaker configuration in the Shark007 Audio TAB.
Discussion Starter · #6 ·
Right, and it is not set to 'passthrough'. Sorry if I didn't make it clear - the PC using analog plays the file fine, while the HTPC that is set to 'passthrough' has problem playing this only one file, out of 200+.
If ONE file out of over 200 is exhibitting an issue, simple deduction analysis would lead anyone to the conclussion that the file itself is faulty. Delete it. Enjoy you HTPC without the hassle.
1 - 7 of 7 Posts
