Originally Posted by jalyst /forum/post/18312425
But isn't the whole point of bit-stream so that (1) better error correction (2) more data in a narrow pipe via compression.
Main reason I care about digi-in (for sound) is for gaming consoles....
I want to use my HTPC as a DH (or similar) adapter, I don't want to use the SU-DH1 or Mixamp...
Also I had planned to keep BD players separate....
Mainly because in Linux it's too much of a lengthy process of 1st ripping then re-constituting (this step not imperative unless storing) before material is played.
Do you know for sure that HDMI-in (bitstream, PCM, whatever) is deliberately locked, or has it just not been utilised yet.
Actually I may have found some solutions:
HDAV1.3 or
Hometheatre HD
A main feature of the HTHD 7.1 is offering HDMI 1.3a I/O to the end user which allows full resolution, high definition audio with no down sampling. A very interesting feature of the HTHD 7.1 is the use of an external receiver is NOT required to have support for these high definition standards.
While the use of an external receiver is an option, the card allows any speaker system connected to the card to output Dolby Digital Plus, Dolby True HD and DTS-HDMA in full resolution.
What's not certain to me is whether these cards can decode/convert DTS/DD formats & pass-through video coming via HDMI, instead of locally.
Even more ideal would be to use my existing Core i3-530 + motherboard w/HDMI-in....
But I'm not sure if
Intel HD Graphics is able to receive A/V via HDMI, let alone decode w/approp. s'ware & redirect to 3rd party DAC.
I doubt it's able to, nor do I expect it'd be possible with sw updates & right mobo/adapters...
The main reasons I want something like this is to;
1) Send digi-Audio (HD or non-HD) to my PC to create virtual surround in stereo (CMSS, DH etc)...
2) Have a PAP* compliant solution so I can receive & play or locally play HD A/V, for the times I'm too lazy to rip/transcode.
It's a shame that I prolly won't be able to redirect decoded DD & DTS formats to my Essence ST + H6 for superior analogue output.
I suspect that'd break the PAP/xxx....
So for analogue-out of received or locally played HD DD & DTS, I'll be forced to use the same card.
Unless I've gone to the effort of ripping & converting beforehand....
*forgotten what the video equivalent is called
