I have an new Samsung DLP HLN567W and just purchased a Zenith Silver Sensor indoor HDTV antenna for over the air high-def broadcasts (Cable company is brining my hi-def box next week for several channles they are carrying).
Set up the antenna and hooked it into Antenna B coax on the back of the tv. Switched tv channels around and only was able to get one chanel (local Fox). BTW I am in Coral Springs, FL.
Ran a channel scan on the TV and it didn't locate any others. Two questions:
1. Do I need an OTA tuner in addition to the antenna?
2. WIll I only get reception on the tv when there is a hi-def broadcast?
