Hi!
I bought a used Ampro 3600. I believe it was made in 1996 or 1997. Its running time is about 1400hours(58days). Tubes are all good, and only Green tube has very slight 4:3 burn(or wear).
The picture is quite strange. (Sources are DVDP and VCR w/o any difference)The center is darker than upper part and lower part. I checked each color. Blue's center is very slightly darker than the other parts. Red's center is worse than Blue's. Green's center is the worst. In fact, Green's upper part is much brighter than the center, and Red's lower part is brighter than the other parts. So, my Ampro's center is darker and bluer than the other parts. Upper part is brighter with Green, lower part has some more red.
In the first place, I suspect it was because of tubes' burn, which turned out not to be true. The darker part does NOT coincide the burned part. Even when I made the image smaller, this symptom was still there. When I turn it off and on after my Apro is warmed up, the picture becomes a little better but still has darker and bluer center.
I don't have any idea of what is wrong.
Please help!
Thank you in advance.^^
Seong
Please help!
Seong
