Status
Not open for further replies.
1 - 3 of 3 Posts
I am running a P4 2.53Ghz, 640megs RAM, GF4Ti4200, and a Revo.
Now, using WinDVD, I am having problems with certain .ts and .trp files. The audio seems to dropout for half a second at random times...usually at least every 20 seconds.
Any ideas what is going on? I am using SPIDF out to my Yamaha receiver then to my Paradigm speakers.
Revo setting is set to digital output.
DVDs are fine...no dropouts. Some HD movies/clips give me the dropouts and I know they should not.
Is it the Revo? I tried to patch WinDVD but the patch said, "you must have a verison of windvd installed for this update." What the hell?!?!
I am using OEM that came with Revo.
Please help.
Thank you.
Discussion Starter · #2 ·
Using VLC,
The files play without the dropouts but VLC will then just lock up at random and the Miscrosoft error report comes up.
Any ideas?
1 - 3 of 3 Posts
Status
