1 - 1 of 1 Posts
I don't think its necessarily specific to the X-Fi Prelude that I have
5.1 analogue outputs from Prelude to Amp
LFE/subwoofer is the output of concern
I realise that unlike the internal processing within most AV amps, most AV amp's multichannel inputs (including my Pioneer) do not include the +15dB gain required for the LFE channel
the query is though if I set within the Creative/Auzentech drivers +15dB for subwoofer output, does that apply +15dB for LFE channel and the re-directed bass (as per crossover) ? if it does I'm not sure if it is correct ? As LFE will still be quieter than the cross'overed bass
or in PowerDVD I can set Front Left/Right and Rears to -15dB, leaving LFE to 0, then with +15dB set in Creative drivers that would mean that both the re-directed bass will be +15dB AND the LFE will also be - IE they both should be boosted by the same amount !
completely confused !!
cheers, Mark.
1 - 1 of 1 Posts
