Status
Not open for further replies.
1 - 7 of 7 Posts
Hello everyone,
I've been lurking this great AVS forum for quite a while. At first, I wanted to buy a $200-300 HTIB systems like Onkyo s570 or Yamaha YHT-150. But now, I want to put together a receiver and speakers for ~ $500 price range. Please help me decide.
I come up with these choices:
Paradigm Cinema 70 $375
Polk RM6750 $325
Athena Micra 6 $290
I plan to get a refurb. Denon AVR-485 at $175
Which combination would be the most appropriate choice?
I've only listened to the Paradigm, I think it's great, but it's from my NuBee standpoint.
Please help me... Thank you very much! :)
Energy's factory-direct store is having a clearance on their Take 5 speaker system in white:
http://www.audioprods.com/clearance_energy/index.php?cPath=41_49
It's $200 for the package and you can get one of those $99 Dayton subs that everyone recommends for budget systems. I think this combination would be better than the ones you listed.
Only thing is that these are white, which may actually be a good thing but it depends on your situation...
I started out with the Paradigm Cinema 70 system several years ago. If your putting it in a small to med sized room it will do a pretty decent job.
I think they are a good starter set-up and will be a much better choice over a HTiB system.
Discussion Starter · #4 ·
OK, Thank you LeeLee for your alternative suggestion
I did some price research.. I can get the:
Take 5 + Dayton 10" sub for $360 shipped
And I also found this Onkyo SKS-HT240 that got a decent review from Cnet
So now we have:
Polk RM6750 $325
Athena Micra 6 $290
Take 5 + Dayton 10" Sub $360
Onkyo SKS-HT240 $360
What do you guys think? Is it much better to get Take 5? I have no clue... I'ma NuBEe
I live in the apartment, will it gonna work with those set up above?
Discussion Starter · #5 ·
I don't know if I've made a good choice, but today I got these speakers (on sales) from Fry's
Polk R50 $120/pair
and
Polk R15 $50 /pair
So... now I'm waiting for a good deal on Polk center speaker (can be bought at $80) and a Dayton 10" sub ($100+20 shipping)
So I'll own this set for $380-400
Add the Refurbished Denon AVR-485 for $160 and I should be ready to go!
What do you think? I just shifted my interest from satellite to a bookshelf and floorstand, is it the same or is it better?
Great deal. I think you'll be very pleased. If you hook into those sales prices, don't look over your shoulder. I love mine. If you can't get the CSi25 from Frys on sale for $100, keep checking ebay. There's usually about 20 centers available. The best matches are CS1, CSi30 or CSi3. Prices range from ~ $100 -$140. Sometimes you get lucky.
Let me know how you like them.
I started out with the Paradigm Cinema 70s. I have used them in my last two apartments (which the neighbors appreciate). I have been really happy with them. I think they sound very good if you have a small to medium size living room. I recommend the following for a starter system:
front - Cinema 70s (with stands)
center - Cinema CC
surrounds - Cinema ADPs
This may be a little over what you plan to pay, but I believe you should spend a little more up front so you don't regret it in the long run.
1 - 7 of 7 Posts
Status
