Status
Not open for further replies.
1 - 9 of 9 Posts
Hey guys. I am going to be purchasing a new sub.
Here are the one's I been looking at:
Yamaha YST-SW315 (10" / 250 watt)
Velodyne VRP-1000 (10")
Velodyne VX-10 (10")
Sony SA-WX700 (2- 10")
Thanks for helping me choose :)
definatly go with a 12" you cant get the solid low freq's i.e anthing below 30ish. the sounds under 30 are your typical explotions, thunder, some guns .... save a little more and get a 12"
Discussion Starter · #4 ·
So Dayton 12" is the one I should go with??
Any other 12"s out there in the $300.00 price mark that would be better then this 12" Dayton?
:) Thanks
I say build one with an Ascendant Audio Atlas or Avalanche, or an Adire Audio Tempest.
How about also considering the Acoustech H-100?
I love my Acoustech H100. I've never heard the Dayton (10 or 12), but I can tell you the H100 will not disappoint you.
That Sony sub is HUGE. Make sure you don't mind the bulk in your room if you go that direction.
Based on people's comments, I'd get the Dayton if I wanted a really inexpensive sub, rather than the Yamaha.
Good luck.
1 - 9 of 9 Posts
Status
