I'm replacing my TX-NR803 due to a surge taking it out during a storm earlier this year. I've narrowed my replacement down to a refurbished TX-NR808 and the TX-NR609.
From what I can tell, the 808 has been a problem child... how do you guys feel about the "fix" that Onkyo has made. Are the issues fixable, and likely to have been fixed on the refurbished units?
As a side issue, I'm feeding this receiver to a Panny TH-50PH9UK via component cables. My sources are a DirecTV HR24 DVR, a Pannasonic BluRay Player, and a Wii.
I'm thinking of upgrading to an HDMI input on the display if I can find the card, but it will only support 1080i. Will I have compatibility issues with my lack of a 1080p display?
I wandered around a store that sells the 609 yesterday, and I'm not crazy about the appearance of the current line, and there's a little bit of a pride issue going from an "8 series" to a "6 series" receiver - but I don't want to deal with a lemon either. Unfortunately the 809 is out of my price range... real estate isn't what it used to be
Which way would you go and why?
Heath
Heath
